Ilya
Aluminum enclosure for PSU - how to connect PE?
« on: May 22, 2020, 05:58:19 AM »
I'm looking at this Hammond enclosure for PSU:
https://www2.mouser.com/ProductDetail/546-1455N1601
I know that per safety regulations the metal enclosure should be bonded to PE. This particular enclosure consists of 4 anodised aluminum pieces: 2 side covers, U-shaped channel and a lid.
My main question is how do I reliably bond all these pieces to PE? Side covers will have some cut-outs, so I can attach bonding wires to one of the screws - this is an easy part.
However, I don't think that I can rely on the connection between side lids and an U-channel. And top cover doesn't have any screws at all.
So how would you go about this? Are there any ways to bond this type of chassis to PE properly?
PCBs, enclosures and build guides at www.rackneve.com
abbey road d enfer
Re: Aluminum enclosure for PSU - how to connect PE?
« Reply #1 on: May 22, 2020, 01:05:31 PM »
I would have a look at these
https://www.hammfg.com/electronics/small-case/extruded/1457-emi
or
https://www.hammfg.com/electronics/small-case/extruded/1455nhd
They have electric continuity between all faces.
Ilya
« Reply #2 on: May 22, 2020, 01:25:28 PM »
or
Thanks. The first one is almost 2 times more expensive, so it's a no-go for now. The second - I still can't see how the lid is connected to other faces....
But you got me thinking in the right direction, I suppose. I believe this case should be suitable:
https://www.hammfg.com/electronics/small-case/extruded/sink-box
What's your oppinion on that?
mjrippe
« Reply #3 on: May 22, 2020, 02:17:02 PM »
If you don't have a bag (or two) of these, here are two sources with part numbers.  ;)
Ilya
« Reply #4 on: May 22, 2020, 02:20:10 PM »
Thanks! I have plenty of  these washers. They are super useful.
Last post April 20, 2006, 09:39:33 AM
by kato
Last post June 17, 2012, 05:29:06 PM
by amaurythewarrior
Last post July 24, 2012, 11:51:18 PM
by HellfireStudios
Last post November 29, 2019, 09:26:49 AM
by Eliani
