Opening Triad Transformers
« on: May 26, 2020, 09:41:47 AM »
Someone cut the leads too short on this A9J...any ideas? Thanks!
Re: Opening Triad Transformers
« Reply #1 on: May 26, 2020, 09:58:25 AM »
looks like plenty unless I'm missing something.   Make splices.
« Reply #2 on: May 26, 2020, 10:07:49 AM »
the bottom piece including the threaded bushing is pressed in, sometimes becomes  loose unintentionally.
hold the the top cylinder, install a long piece of 3/8" threaded rod with a coupler onto the stud, and wiggle it loose.
3/8" X 32 threaded rod can be found at hardware stores that sell table lamp parts.
« Last Edit: May 26, 2020, 01:31:46 PM by gridcurrent »
mjrippe
« Reply #3 on: May 29, 2020, 03:43:51 PM »
That looks like plenty of wire to me too.  Like Doug said, splice it.
Now these were cut too short.  Note the one in front where I cut off the threaded part to get enough wire to splice to.
« Last Edit: May 30, 2020, 01:47:14 AM by mjrippe »
« Reply #4 on: June 01, 2020, 07:43:46 PM »
You accidentally grinded through the insulation of the cables  :-[
mjrippe
« Reply #5 on: June 02, 2020, 04:36:10 PM »
Well spotted!  I had some plastic tubing over the wires to try to protect them, but it was not enough.  Will try to find metal for the other three.  I believe I can splice and heatshrink the ones that I nicked.
Last post August 23, 2017, 12:27:30 AM
by PRR
Last post June 21, 2008, 11:18:51 PM
by EmRR
Last post January 19, 2012, 11:06:49 PM
by CJ
Last post October 09, 2019, 03:57:28 PM
by damiangiannis
