johnheath
19" Chassis
« on: May 27, 2020, 05:48:29 AM »
Hi all...
I have been looking through the internet trying to find a solid dealer in sturdy 19" chassis... preferably in Europe.
There are many manufactures and vendors but much of the stuff is rather flimsy.
I am looking for sturdy chassis to build a rack mounted tube power amp. It includes a pair of hefty transformers so weight will be a problem.
I have connections to make plates and like to increase durability but I cannot seem to find frames or chassis suitable for the task.
Best regards
/ John
Nothing is impossible - It just takes some more time
johnheath
Re: 19" Chassis
« Reply #1 on: May 27, 2020, 05:52:29 AM »
Forgot to mention that I prefer aluminum chassis since drilling big holes in steel sheet is a PITA :)
Best regards
/ John
scott2000
Re: 19" Chassis
« Reply #2 on: May 27, 2020, 08:16:58 AM »
I think the Bud (AC series?) are pretty well regarded as a quality chassis.....
johnheath
Re: 19" Chassis
« Reply #3 on: May 27, 2020, 09:16:22 AM »
Thank you Sir
I had a closer look at their website and it seems like they are limited to 0.09" thickness which might be on the low side. Most of the chassis is made from 0.05" aluminum sheet and that is too thin for this project I am afraid.
Best regards
/ John
Gold
Re: 19" Chassis
« Reply #4 on: May 27, 2020, 12:50:15 PM »
One thing I’ve done is add a metal sheet to the bottom of the case. Some cases have threaded inserts to mount the bottom plate. You can remove those with a pin punch and secure both bottom plates with a screw and nut.
tony hunt
Re: 19" Chassis
« Reply #5 on: May 27, 2020, 12:53:38 PM »
Have you checked the V-Case 19" system from Germany?
Re: 19" Chassis
« Reply #6 on: May 27, 2020, 04:00:51 PM »
With serious weight to carry you should probably thinking about using a standard Eurorack sub-rack type of construction. These use 2.5mm side plates connected together by very sturdy aluminium extrusions. There are version for everything from light industrial ones suitable for trains. Many depths are available and top and bottom screens are also available. There are many manufacturers of these in Europe. The all meet the relevant DIN standard but their parts are not interchangeable so you basically need to pick a vendor and stick with them. The obvious European candidates suppliers of sub-racks are:
Schroff  (Germany)
Fischer (Germany)
SRS (UK)
Rob Flinn
Re: 19" Chassis
« Reply #7 on: May 29, 2020, 07:46:59 AM »
I've been using this series of case for 20+ years.  Solid & cheap !
https://cpc.farnell.com/penn-elcom/r2100-2uk/19-rack-box-2u-220mm-deep/dp/EN55272?ost=en55272
regards Rob
Re: 19" Chassis
« Reply #8 on: May 29, 2020, 05:39:42 PM »
I see these have an aluminium front panel. Is the rear panel also aluminium?
johnheath
Re: 19" Chassis
« Reply #9 on: May 30, 2020, 05:47:22 AM »
Thank you all for your replys
I have been looking through the proposed webesites and I found this 19" rack mounted chassis.
https://www.fischerelektronik.de/web_fischer/en_GB/cases/N02.02/19%22%20plug-in%20boxes/$catalogue/fischerData/PR/VESA_GT2_70/index.xhtml
The technical drawing is not all too revealing and it seems to be 1,5mm thickness aluminum... I would prefer a bit thicker.
But the link with the 3U chassis is very close to what I am looking for... even a 4U would be fine... depth 2-3 inches (or 5 - 7,5cm)
Best regards
// John
Rob Flinn
Re: 19" Chassis
« Reply #10 on: May 30, 2020, 03:39:39 PM »
Only the front panel is aluminium, everything else is steel.
regards Rob
Re: 19" Chassis
« Reply #11 on: May 30, 2020, 05:05:45 PM »
How do you get on making holes in the steel rear panel? I have always found steel to be a PITA.
NOON
Re: 19" Chassis
« Reply #12 on: May 30, 2020, 07:10:43 PM »
Hole punches for XLR and DB25, dremel, drills, files, foul language and skinned knuckles for IEC connectors.
Rob Flinn
Re: 19" Chassis
« Reply #13 on: May 30, 2020, 07:14:52 PM »
Hole punches for XLR.  Drill and jigsaw for i.e.c.    Drill and jigsaw for DB25.     I'd like a punch for the i.ec, but after 30 years I have the drill and jigsaw down pretty quickly nowadays.
regards Rob
Re: 19" Chassis
« Reply #14 on: May 31, 2020, 03:53:50 AM »
OK, got it. Jigsaw helps a lot. It's the final filing that always gets me. Doesn't help having arthritis in my knuckles.
Cardinen
Re: 19" Chassis
« Reply #15 on: May 31, 2020, 06:09:34 AM »
I’ve been using these rack for years now, good service for customization also:
https://modushop.biz/site/index.php?route=common/home
SSLtech:  "Because not all that matters can be measured, and not all that can be measured matters."
johnheath
Re: 19" Chassis
« Reply #16 on: June 01, 2020, 11:10:39 AM »
Thank you Sir
Me too in fact... especially for all types of preamps, compressors and like.
Thing is that I now are trying to find something other than what they offer... otherwise they have very good products
Best regards
/ John
Rob Flinn
Re: 19" Chassis
« Reply #17 on: June 01, 2020, 03:43:02 PM »
Good quality files & a depinning brush to keep them clean makes it much quicker.
regards Rob
Whoops
Re: 19" Chassis
« Reply #18 on: June 06, 2020, 08:00:32 PM »
Most sturdy I bought in Europe are from Modushop, great cases and a lot of options:
https://modushop.biz/site/index.php?route=product/category&path=171_228
https://modushop.biz/site/index.php?route=product/category&path=208_268
Last post June 28, 2006, 06:37:35 PM
by dissonantstring
Last post April 09, 2010, 01:22:51 PM
by tv
Last post December 15, 2011, 07:42:23 PM
by r2d2
Last post April 16, 2020, 01:19:18 PM
by mjrippe
