rockinrob86
Stopping hum in steel chassis
« on: May 29, 2020, 12:51:43 PM »
I have an akai/roberts open power transformer in a preamp build.  The preamp is quiet, until I put the cover on or put it in my rack, and then it hums.  I am thinking this is due to the PT radiating to the steel cover.
Any way to eliminate this?
Fuzz Face
Re: Stopping hum in steel chassis
« Reply #1 on: May 29, 2020, 02:51:29 PM »
You can make a mu metal shield around the transformer
rockinrob86
« Reply #2 on: June 07, 2020, 03:14:11 PM »
Thanks.  I ordered a mu metal sheet and cut a box to put around the OT.  It dropped the hum from -40 or so to around -70.  I have a hum reduction plug in that makes it silent and I don’t hear negative consequences, so I think I’m good with this one.  I think when I use the other Power transformer I will mount it in a box on the back and run wires inside rather than putting it in the chassis like I did this one.
CJ
« Reply #3 on: June 10, 2020, 03:20:35 AM »
when you put the lid on you complete the magnetic circuit.
you could try using the lid only insulate it from the rest  of the box somehow.
Frank's Tube Page: www.mif.pg.gda.pl/homepages/frank/vs.html
Guitar Amps: http://bmamps.com/Tech_sch.html
« Reply #4 on: June 10, 2020, 04:45:22 AM »
Or change it to aluminium.
abbey road d enfer
« Reply #5 on: June 10, 2020, 05:49:13 AM »
Transformer-induced hum results from a combination of magnetic field reorientation and eddy currents. Al does not reorient magnetic flux but it closes the shorted loop.
rockinrob86
« Reply #6 on: June 10, 2020, 10:06:05 AM »
It also hummed when I put it in the rack without a top on, although the piece of gear above it is steel as well.
abbey road d enfer
« Reply #7 on: June 10, 2020, 01:46:09 PM »
Does it change if teh piece of gear on top is ON or Off?
rockinrob86
« Reply #8 on: June 11, 2020, 01:08:11 PM »
No it didn't
12afael
« Reply #9 on: June 11, 2020, 01:25:03 PM »
It is the transformer isolated from the chassis? Some amplifiers have some isolating material between chassis and the transformer and special groomets to attach the screws.
heavy metal is the law!!!
Last post April 20, 2006, 09:39:33 AM
by kato
Last post April 25, 2007, 12:58:19 PM
by
Last post February 14, 2010, 06:09:33 PM
by pietro_moog
Last post April 09, 2010, 01:22:51 PM
by tv
