Daking Mic pre / Eq transistor question
chops
Vancouver
I’ve searched hi and low for schematics, but no luck.  Does anyone know what transistor Q4 on the daughterboards is?  I’ve tracked my problem down to that transistor (I hope) and a burnt 10ohm resistor on the same daughter board.  All other components test OK including the other transistors.  (At least with a simple DMM diode teat.)
Swapping with a daughter board from another channel solves the problem.  So if I can just replace that transistor, all should be well.
Any photos of the board you might be able to provide? And/or what role that transistor might have in the circuit, or at least what "stage" / section it's involved in, what it's connected to?
Thanks Khron.  Geoff  Daking himself was kind enough to confirm the part in question.  2N4036 (with a heat sink)
