> offset is largely determined by the bias current in the LTP. Grrrrr.
By the current-match across the pair.
If you take only one output from the pair, yes, you can "trim" the tail current. Like if your boat is bent, you may be able to ballast it to go straight. But it may be more elegant (and lower THD) to make both sides the same.
