radiance
Cheap & Simple PCB design software
« on: June 18, 2020, 02:50:37 PM »
I used to work with RIMU pcb software but the developer;s website  (Hutson Systems ) is no longer.
Can anyone recommend any simple PCB software like Rimu?
It's just for a small project so I'm not going to spend a lot of money on it.
"Knowing that you are dreaming, however, does not automatically guarantee full rationality.
Then again, being awake doesn't ensure good thinking, either." -  Lynne Levitan
pucho812
Re: Cheap & Simple PCB design software
« Reply #1 on: June 18, 2020, 02:53:21 PM »
check out kicad.
https://kicad-pcb.org
You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is.
peterc
« Reply #2 on: June 18, 2020, 02:59:15 PM »
Mac, PC or Linux
If opportunity doesn't knock, build a door.
radiance
« Reply #3 on: June 18, 2020, 03:15:39 PM »
Thanks Peter! Will try...
It's for PC
« Reply #4 on: June 18, 2020, 03:22:29 PM »
EasyEDA, its free and easy to learn.
https://easyeda.com
peterc
« Reply #5 on: June 18, 2020, 04:18:27 PM »
Radiance
I use Circuitmaker and Traxmaker for PC.
The maker has gone out of business. I use Circuitmaker for simulation which seems OK. You can also export the circuit into Traxmaker for auto routing, but I dont use that function so I cant comment on how good it is.
All my boardsI route manually in Traxmaker and it does the job for me.
Hope this helps
Peter
jensenmann
« Reply #6 on: June 18, 2020, 04:40:33 PM »
I started using Sprint Layout. It´s 50 bucks and very easy to learn. I´ve done my first PCB after 2 hrs.
Jens
Quote from: PRR
The tubes of course don't care what frequency they distort
radiance
« Reply #7 on: June 20, 2020, 03:26:20 PM »
Thanks for all suggestions....this still is a great community!
Last post February 11, 2005, 01:46:26 AM
by pstamler
Last post December 27, 2007, 02:18:33 PM
by keefaz
Last post September 10, 2008, 07:09:37 PM
by druedger
Last post December 01, 2009, 04:07:31 PM
by ruffrecords
