BerndVP
Warm Audio WA412 Mod
« on: June 24, 2020, 03:37:39 PM »
I have an Warm Audio WA-412 and think about changing the:
Input transfo, Output transfo and DOA to CAPI ones.
What are the things I need to be checking before changing those components?
TillM
Re: Warm Audio WA412 Mod
« Reply #1 on: June 24, 2020, 04:37:08 PM »
I would first change the DOAs and check if it makes a difference.
I think the altran xfr make a good job.
Sure the Capi transformer are top notch, but before you spend a lot of money for new ones, I would first try the DOAs.
I don’t know the circuit from the warm audio, but by changing the input Trafos you maybe need a new Zobel network.
Also the pinout from the transformers could be a bit different to the Capi ones.
BerndVP
« Reply #2 on: June 25, 2020, 03:02:17 PM »
Thanks for the reply!
I ordered new DOA first then.
I see they’re using JH capacitors.
Was maybe thinking swapping them out for Nichicon.
https://www.jianghaius.com/PDF/CD263-1.pdf
What do you recommand?
TillM
« Reply #3 on: June 25, 2020, 04:05:22 PM »
Why want you change them ?
It makes no sense in my opinion.
« Reply #4 on: July 06, 2020, 12:05:22 AM »
Genuinely curious if this unit needs mods except for the op amps. Anyone have some insight?
« Reply #5 on: February 23, 2021, 12:40:14 PM »
I know this is an old thread. I just bought a Warm WA-412. I'm not sure what everyone thinks they will gain by replacing the DOA and transformers. It seems to do the API kind of thing fine as is.
3nity
« Reply #6 on: February 27, 2021, 09:49:29 PM »
Don't those pres use Cinemag transformers? If so no reason to replace them.
Life is a path, death the destination.
Last post March 06, 2019, 11:57:55 AM
by andre tchmil
Last post December 04, 2018, 11:56:29 AM
by easymix
Last post January 28, 2019, 01:10:11 PM
by analogguru
Last post September 19, 2019, 07:48:27 AM
by r2d2
