I’m planning out some DIY preamp modules with 4u front panels and I’m wondering if any one here has experience w PCB brackets to mount the electronics and so forth?
I want something like a 6” height L-bracket to bolt onto the 7” front panel and go 5”-7” deep into a rack. I’ve found sub module insert kits by Vector that contain a front panel and PCB bracket but they're only made in a 9” deep size for 4u. Plus, I only need the bracket, and I’d have to buy the whole module kit for $50 per module plus shipping. I don’t know how easy it would be to snip off the excess bracket depth.
Wondering if there might be other pre-fab options available, or if it’s a pretty easy matter to just buy sheet metal and bend and drill my own brackets.
What would you do for mounting brackets?
Re: PCB mounting brackets for 4u module? Prefab options? DIY options?
« Reply #1 on: June 29, 2020, 04:10:40 AM »
For Eurocard PCBs there are standard mounting brackets in the form of a die casting that attach a PCB to a front panel:
https://www.newark.com/schroff/60807-181/printed-board-bracket-plug-in/dp/65T0174?ost=2292872.&iscrfnonsku=true
« Reply #2 on: June 29, 2020, 05:57:30 PM »
Ok, this looks like a good option if I can’t find or manufacture a practical one piece L-bracket.
I was looking at a photo of one of your tube modules after posing my question and noticed how solid and sturdy it appears. Thanks for the link.
shabtek
« Reply #3 on: June 29, 2020, 11:14:05 PM »
if you build more than 1 it might make sense to adhere to or borrow from an established standard, even adding 1/2 top and bottom to a 3u standard. CAPI used to sell an L bracket for 500/51x, eurocard is similar,  schroff vme  might have parts you can use
"really fine players do not use stomp boxes or master volume, they match the amp to the room and turn it up to 11.  Stevie Ray, BB King, Albert King, Duane Allman, Dicky Betts, Louis Armstrong"
   -CJ
Last post November 28, 2005, 06:36:43 AM
by guavatone
Last post July 08, 2006, 12:41:46 PM
by jdbakker
Last post July 27, 2008, 03:55:56 PM
by signalflow
Last post June 17, 2019, 04:02:32 PM
by ruffrecords
