Help with Front Panel Express
dismal
New member
Hi, I am currently doing the DIY Studer 169 EQ 500 series and I need some help with Front Panel Express, I had no problem making my faceplate with every holes placed but I don't understand how to do the -12 to +12 DB with the little lines on the gain button.
Can someone help me with this?
You can do patterns easily with Autocad type software.
You can also brute force it with a spreadsheet to calculate the appropriate marker coordinates.
Many years ago someone posted a program that generates and HPGL file of a scale specified by inputs to the program. This can be imported into FPD and saved as a user macro object. It can then easily be imported into a front panel and it can also be scaled.
Note also that FPD has for some time allowed the import of a dxf file of the panel outline. In the latest version this has been upgraded so an entire panel expressed as a dxf file can be imported (outline, holes and text etc). I have not tried this yet.
dismal,
Frank Rollen has some panels for that in his inventory if you want to check out his stuff. I am building 6 of those Studers right now and got my panels from him. He can make them any color panel and ink you want.
