john12ax7
Need M7x0.75 11mm panel nuts for Alps pots
« on: June 30, 2020, 11:05:54 PM »
Does anyone have a source for replacement nuts for Alps pots? I need M7 x 0.75 with a width of 11mm (see attached pic).
The 10mm width is common and available, but no one seems to have/use the 11mm version except for Alps.
gyraf
Re: Need M7x0.75 11mm panel nuts for Alps pots
« Reply #1 on: July 01, 2020, 04:24:26 AM »
This is what Taiwan-Alpha uses in their RV16xx series, I think..
JohnRoberts
« Reply #2 on: July 01, 2020, 09:51:16 AM »
how many do you need,,,,?
I have lots, and lots of alps pots too left over from my old kit company.
Don't only half-ass tune your drums. Visit https://circularscience.com to hear what properly "cleared" drums sound like.
john12ax7
« Reply #3 on: July 02, 2020, 04:21:20 PM »
Found some Alpha RD09 pots in the parts bin,  but they too are 10mm, not sure about the RV16.
I probably need 100-200. But if the Alps pots I need are available, that's even better.
JohnRoberts
« Reply #4 on: July 02, 2020, 04:57:36 PM »
I still have piles of 16mm  1x100kB (linear)pots, and 2x50kB (S taper) from my old kit company.  These pots are a few decades old so will probably end up in a landfill, sometime after I do...
john12ax7
« Reply #5 on: July 02, 2020, 05:08:25 PM »
Sent you a PM but seeing now you replied here.  Those values wouldn't work,  but maybe the nuts would.
It's the perils of trying to do small scale manufacturing with off the shelf parts.
JohnRoberts
« Reply #6 on: July 02, 2020, 07:34:09 PM »
I could slide you a couple hundred nuts (and matching flat washers too) but how can you buy pots without nuts?
This will make my pots orphans but they have been sitting for decades and I have no plans for them this lifetime... maybe I should design more kits... nooooooooo.
john12ax7
« Reply #7 on: July 02, 2020, 07:53:01 PM »
The issue is I need two different pots,  one is M9 the other M7. Since the knobs don't completely cover the nuts would prefer that both nuts be 11mm. I could send you the M7 10mm nuts to replace.
It's essentially a way to get something done if the MOQ for the more proper solution is not reasonable.
JohnRoberts
« Reply #8 on: July 02, 2020, 08:36:01 PM »
PM me your address and I'll drop a few in the mail so you can see if they'll work and you actually want them...
JohnRoberts
« Reply #9 on: July 03, 2020, 10:10:55 AM »
a couple nuts and washers are in the mail...
john12ax7
« Reply #10 on: July 03, 2020, 08:21:49 PM »
Thank you.
john12ax7
« Reply #11 on: July 10, 2020, 08:25:39 PM »
Got the nuts, they are the correct size.  So it's a viable solution if the MOQ doesn't work out.
JohnRoberts
« Reply #12 on: July 10, 2020, 11:11:52 PM »
let me know I have hundreds...(left over from my 80s kit business... )
JohnRoberts
« Reply #13 on: July 17, 2020, 10:48:31 AM »
after a couple weeks I am returning the nuts to my back store room...
moamps
« Reply #14 on: July 17, 2020, 02:14:23 PM »
C'est la vie..
Cheers!
JohnRoberts
« Reply #15 on: July 18, 2020, 09:37:03 AM »
C'est la vie..
Cheers!
Ċ½ivjeli
john12ax7
« Reply #16 on: July 18, 2020, 07:21:56 PM »
I have to finish and order the PCBs and metal work, so might be a little time before I need them in bulk.
Last post April 10, 2005, 09:34:59 AM
by VacuumVoodoo
Last post December 01, 2005, 01:59:14 PM
by bladerunner
Last post September 18, 2012, 10:03:46 AM
by Kingston
Last post July 25, 2018, 02:31:05 PM
by dirtyhanfri
