Should the capsule be isolated?
liquidfuzz
Active member
I'm in the process of designing a chassis, capsule holder etc for a microphone. The microphone is based on a circuit i found on this side will building some diy power supply. The circuit's schematic is posted in a thread called Official C12 Clone - Build and Support Thread. I have a question regarding the capsule. Should it be isolated or connected to the chassis ground?
  • dump.pdf
Most likely isolated - depending on the design, the backplate might have some bias voltage applied to it, or it may even be used as the signal source, connected directly to the JFET gate / tube grid.
IIRC Rossi or maybe someone else had a good thread about a conductive mount issue
