Single Phantom Resistor??
« on: July 19, 2020, 06:00:01 PM »
I've been messing around with my Crown CX822 to try and make it useful in the studio.  It has a non defeatlable +48V supplied to the mic inputs at all times.  I was planning on disconnecting this but when I went in to to do it, I noticed something different.  Instead of feeding the phantom via both (5.6 kohm resistors in this case) phantom resistors, the +48 was fed through only one of the resistors and then was split after the single resistor to feed pins 2 and 3 of the XLR.  I'm wondering if this is kosher or not???  If it was, why are most people going through the trouble to match two 6.81K resistors closely?
Re: Single Phantom Resistor??
« Reply #1 on: July 19, 2020, 06:05:55 PM »
not totally following your description, seems to suggest there's a pair of phantom resistors but only one used, or something.  Drawing?
« Reply #2 on: July 19, 2020, 06:27:32 PM »
Excuse my comically poor drawing abilities  ;D.  The drawing on top with the two matched phantom resistors is what I assume the typical arrangement is.  The bottom drawing is what I actually found inside the tape machine.
It had obviously been changed at one point as I could see that the wire that was orignally fed from the other 6.8k was moved over to the only 6.8k in use.  The resistors are old carbon comps so I could understand if they drifted way out of tolerance.  I'm just wondering if this single phantom resistor scheme is OK or not? If not, why?  CMRR?  Would I be better off buying 2 new high tolerance metal films instead of this odd single resistor scheme?   I'm wondering if this was the reason I was never satisifed with the mic inputs on this machine because with a condenser mic hooked up, I was always getting a ton of radio interference.
« Reply #3 on: July 19, 2020, 06:31:42 PM »
Well something is still missing.  What you've drawn is a shorted mic, with typical connections.   Which would be why it isn't done.  6K8(x2) makes a 13K6 load in parallel with the preamp input impedance.   The version with a single resistor feeds  through a 3K4 to the center tap of an input transformer primary.
« Last Edit: July 19, 2020, 06:36:03 PM by EmRR »
« Reply #4 on: July 19, 2020, 09:41:54 PM »
I agree, that's why I'm confused.  To add some missing information.  The two wires connected to the feed of the single phantom resistor go into what I assume to be the mic input transformer.  There are two more pairs of wires exiting the presumed transformer, with one pair going to pins 2 and 3 and the other pair going to what I assume is the input of the preamp.  This setup is also only bringing about 30VDC to pins 2 and 3, which doesn't seem like enough for any p48 mic.  I'm thoroughly confused here.
« Reply #5 on: July 19, 2020, 10:15:37 PM »
Sounds like the CT approach, almost.....keep drawing......
JohnRoberts
« Reply #6 on: July 19, 2020, 10:54:51 PM »
or wrong.... A single phantom resistor would need to feed two extra degeneration resistors to force sharing... the total impedance  wants to be 3.4K (6.8K in parallel with 6.8K).
Don't only half-ass tune your drums. Visit https://circularscience.com to hear what properly "cleared" drums sound like.
abbey road d enfer
« Reply #7 on: July 21, 2020, 06:12:52 PM »
I think the phantom resistor feeds the center tap of the xfmr's primary.
Last post March 21, 2006, 04:50:54 AM
by so
Last post March 13, 2009, 10:52:07 AM
by Steve Hogan
Last post October 28, 2010, 05:30:26 PM
by matta
Last post June 26, 2013, 05:20:31 AM
by Script
