Rob Flinn
Hi I have a couple of looms here that are wired for SSL DL pinout. Probably line in or out. One is 32pr cable the other 24pr cable. The owner needs Dsub25's put on one end. I know, you may say that the cores of the multcore will be numbered so I don't need the pinout. However the cable is the type with changing colours for the various pairs so I need the pinout to determine which is hot & cold. Does someone have the pin out they could share with me please ?
