turntable psu (24v sine wave)
buschfsu
jacksonville FL
hi all,
looking to replace my wall wort on my rega p3 with a diy linear psu.  would a conventional toroidal with caps into a 24v zenner give me better results that the smps it came with?  i hear the 400$ upgrade from rega produces a clean sine wave at 24 v (don't care about the 45 vs 33 rpm switch)
thanks
jason
I don't really know turntables but is the motor different? An SMPS makes DC which would suggest that you currently have a DC motor. If this "upgrade" uses 24VAC, then it sounds like that's only for an AC motor.
Hello
yes... same question, it's confusing, do you need AC or DC to drive the turntable ?
The motor ? Or it's for embedded electronic ? RIAA and line out ?
Best
Zam
Some audiophiles believe that powering an AC motor from something like a 20W audio amp with a "clean" sinus will offer better wow and flutter numbers.  ::)
So I'm guessing it's an AC motor.
Mains THD can be high (up to 10%), so a good oscillator and output amp  will produce obviously cleaner power supply for a synchronous motor.
@jason
Could you provide detailed info about motor your turntables uses right now, and which version of the turntable you are using (P3 or planar3)? There are lot of infos on the web about mods on Rega turntables.
It would be a big surprise if it was a synchronous AC motor. Especially if it's not clearly marked. It would have to be specified for either 50Hz or 60Hz operation.
It would also have to be line voltage. It couldn’t be 24VAC unless the line voltage went though an auto former  or transformer which wouldn’t make much sense.
Does the wall wart have an AC or DC output? If it has an AC output the regulator is in the turntable chassis. There is not much to be done about that short of surgery.
If the wall wart is a cheap SMPS then just replace with something better.
Indeed.
buschfsu said:
hi all,
thanks
jason
I don't know  if I totally understand your question,
but a full bridge rectified Linear PSU using a 24VDC regulator (LM7824 or LM317), with proper filtering (Capacitance) is really easy to do, not expensive and will provide completely stable and regulated output with Low ripple.
hey guys
sorry wasnt seeing the responses..
the motor is from the vpi prime. so its 300 RPM, 24 pole, AC synchronous motor.  they sell an ADS power supply but was wondering if i could do better or cheaper
thx
For an AC motor you don't want capacitors or zeners or anything else. Honestly an over-sized AC wall wart would work about as well as anything.
If you really wanted to get pedantic about it, you could feed wall-wart AC into a choke from a hi-fi or guitar amp in series with the right capacitor(s) to get a resonant 60Hz band-pass filter and make the purest sine wave that fancy motor will ever see. Angels will descend from heaven to listen to it and complement you. But the filter would have to be designed carefully and tested to consider tuning and power requirements.
