elskardio
Re: That 1512 gain adjustment driving me nuts!
« Reply #20 on: July 24, 2020, 12:57:32 PM »
Tolerance is not the issue. When I mentioned C3, it's not the tolerance, it's the taper. I seriouslky doubt guitar amps use C3 pots.
According to That’s design note, the gain trajectory vary depending on the reverse pot tolerance.
abbey road d enfer
« Reply #21 on: July 24, 2020, 02:00:05 PM »
Read again:
"Eigure 3 shows how the decibel gain of the circuit of Figure 2 varies with pot rotation using a 1510 and various 10 kΩ pots for RGV. The pots are all reverse audio (log) taper, usinga two-segment piece-wise linear approximation to the log function; the tapers vary from2.5% to 20%. "
Not tolerance, taper The graph shows clearly that C2.5 gives the smoothest law.
elskardio
« Reply #22 on: July 24, 2020, 02:08:35 PM »
Oops... my bad. Thanks
Last post April 10, 2005, 09:34:59 AM
by VacuumVoodoo
Last post July 15, 2008, 08:14:08 PM
by pstamler
Last post January 21, 2009, 09:22:18 AM
by geoff004
Last post December 20, 2018, 02:51:15 AM
by ruffrecords
