Trying to put together a +24 and a 48v supply. I’ve been wanting to use a smps for sometime but have been hesitant. I know it’s totally doable and has been done for many years. I just don’t understand them as well as a linear design.
Anyway, I’m looking at using a 2.1amp GLc50-24 since I have one already and I know API use them in some of their 500 series supplies.https://www.mouser.com/datasheet/2/373/sl%20power_glc50_ds-1203484.pdf
Any advice on filtering? I’m reading about using chokes and inductors but not sure where to start.
I'm not familiar with this particular SMPS, since I've used only SunPower and XP power, but I found they are very easy to filter with an additional CLC filter. The first C is determined by the datasheet, in my case 100uF, then the inductor is a 10mm 12uH, followed by two 470uF, that is
not Low-ESR. The units powerd by them are dead quiet.
I haven’t decided on what 48v supply for phantom yet. So open to any recommendations.
I would not hesitate to recommend one the XP power; there's a 5W and a 10W. You're probably aware that smps should not be underloaded, so teh 5W is probably the best bet for 8 channels. You'll have to load the smps with a resistor that draws about 2W. A 1.2K 5W resistor and an LED drawing another 20mA should do.
