Looking for ACP88 schema
plimousse
Nantes - France
I have one unit on my workbench, with some trouble in attack, release for 2 channels.
If someone have schematic diagram ?
Pascal
Most likely cold solderjoints. I had two of them on the bench with that fault. Use an isolated screwdriver to press on the rear of the frontpanel PCB while it´s in use. See/listen if penetrating the PCB changes the behaviour. If so then resolder the area on then PCB.
