Has anyone heard one of these mics? The XFY54 is one of those low voltage sub-miniature pentode tubes with 1.25 vdc direct heated filament and 67.5 volts anode, intended for battery operation. The tube appears triode connected in the schematic. No output transformer in the mic, medium impedance output coupled off the anode to a transformer in the power supply. Noisy? Prone to hum, RFI, etc.?
Appears that mic could be run off a single flashlight battery for heater and seven 9 volt batteries in series for the anode...
