camarada78
Transformerless Line to Amp circuit.
« on: August 27, 2020, 03:11:22 PM »
Is there a simple "standard" circuit to make a Line to Amp (reamp box) without the use of transformers?
I already have one with transformer (edcor) and I would like to compare to a transformerless version.
Have a good day.
Anything that is too stupid to be spoken is sung
fazer
Re: Transformerless Line to Amp circuit.
« Reply #1 on: August 28, 2020, 05:14:22 AM »
The transformer is for galvanic isolation.  The ground loop is eliminated with the transformer. Not so easy without.  I don’t know of a circuit that can do that without a balanced input. Typically unbalanced is  used on instrument (guitar/bass) amps.
abbey road d enfer
« Reply #2 on: September 16, 2020, 04:38:37 PM »
It is quite possible. It's a basic differential line receiver, which could be a one opamp gig, a 3 opamp gig, or use a dedicated chip (E.G. THAT1206). It should be powered from a source referenced to the guitar amp, or off batteries.
camarada78
« Reply #3 on: September 28, 2020, 11:31:00 AM »
Supposing i dont have ground problems on the setup, a simple balancing circuit would do the trick?
abbey road d enfer
« Reply #4 on: September 29, 2020, 12:47:25 AM »
Yes.
My3gger
« Reply #5 on: September 30, 2020, 03:46:01 PM »
Have a good day.
Hello,
could be interesting comparison if you don't get into troubles with ground. I tested 2 other transformers and Edcor, used mainly with guitars (clean and distorted). Sound wasn't really different with the same signal levels, guess instruments had a lot more distortion than circuit. Passive is probably cheaper compared to expense for psu with transformer, bigger chasis, etc.
Let us know how you like it regarding sound and ground.
Last post May 05, 2005, 03:46:46 AM
by Learner
Last post June 11, 2007, 07:59:43 PM
by mich
Last post April 21, 2018, 04:30:18 PM
by zamproject
Last post June 16, 2020, 10:23:37 PM
by Dualflip
