Looking For a Phantom Power PCB With 15VAC Input
cpsmusic
Melbourne, Australia
Hi Folks,
I'm currently repairing a tube mic pre built by my late-Father. To get the 48V phantom power he tapped the HT which I can see is a bit dangerous! The power transformer has a 15VAC winding which I would like to use for phantom power. Does anyone know of a PCB that would be suitable for this (15VAC -> 48VDC). The only one I've been able to find is the G9 although it has additional sections that I don't need.
Chris
cpsmusic said:
Hi Folks,
Chris
If you want 48V from 15V you need what is called a boost converter, it is a switching converter that will raise the voltage, however it will need some filtering.
Not necessarily - you'll note the thread title says "15V AC". With that, just a simple voltage tripler might suffice ;)
https://en.m.wikipedia.org/wiki/Cockcroft%E2%80%93Walton_generator
https://www.electronics-tutorials.ws/blog/voltage-multiplier-circuit.html
The innards of such a unit do this trick:
https://www.ebay.com/itm/AC-48V-Phantom-Power-Supply-USB-Power-Adapter-For-Micro-Condenser-X5P6-M2P5/174311917973?hash=item2895ccc995:g:3uYAAOSwB7le3~CL
