I just picked up this box that was apparently built at 30 St. Studios in 1950.
The person I got it from bought it at auction from RCA 24th St. when they closed, and they gave him all the info on it. Apparently it was moved to RCA sometime in the early '60s.
It's a 2-1 preamp/mixer, obviously all tube, with a Thordarson output transformer. Originally they had two external boxes with input transformers in them, one with Thordarsons wired for 30:50k and the other with UTCs for 600:50k. I just bought a couple of OP-6 transformers from Doug Williams, thinking those will do nicely, at least until I can find the original Thordarsons.
Supposedly they used this in the '50s for ribbons but also to DI electric guitars and basses. As far as I know that wasn't common practice until much later? The two inputs on the front labelled "Microphone" are essentially the same circuit, but the two non-labelled ins are not. The mic inputs run through 4 triode stages in total, with the attenuators between the 2nd and 3rd (mixer) stages. However, the left non-labelled input goes directly to the attenuator, while the right goes to the 2nd stage. Maybe this was to have 2 lower gain inputs that were out of phase with each other? Any other thoughts?
