Rob Flinn
As it says in the title.
regards Rob
Whoops
Hello Rob, you're not a new member, you're here for a long time.
How about forum rule 6:
6. Use the search function (thoroughly) before posting.
 ;D ;D ;D ;D ;D ;D ;D ;D ;D ;) ;)
https://groupdiy.com/index.php?topic=71380.0
Rob Flinn
Despite your assumption I actually did use the search function before I posted, but I didn't find that.    But thanks for posting that link.
« Last Edit: September 23, 2020, 04:38:54 PM by Rob Flinn »
regards Rob
Whoops
second result in google
gyraf
squarewave
I really like that circuit. Input level control is slick. No noise reduction BS. Simple fast limiter. Simple BAX tone. Good mix controls that can make 100% wet. Too bad we can't see part values. I wonder if there's any pre-post emphasis.
Whoops
I got really curious about this unit, would love to try it out.
How does it sound Rob?
Regards
Rob Flinn
Regards
Let me fix it first before I can evaluate it properly.   The owner really likes it for vocals.   It's not like an AKG which is slick & plate like, it sounds like you expect a spring reverb with a smallish tank to sound.
regards Rob
Rob Flinn
It sounds pretty decent for what it is.     I particularly like the tone controls on it, you can get some nice sounds using them.    It's not like an AKG BX series, but it has a really nice sounds.  Using it at quite a low level compared to the dry it has nice ambiance to it.
« Last Edit: September 28, 2020, 01:05:42 PM by Rob Flinn »
regards Rob
Whoops
At the end of the day it sounds like a spring reverb, it's not like an AKG BX series, but it has a nice sound.
Nice, I love spring reverbs.
The BX20 is amazing but it sound more like a plate than a spring
Rob Flinn
You would probably like this box.  It's very useable.
regards Rob
Sorr
What sort of spring does it use?
Rob Flinn
Just a pair of regular looking spring tanks, but the cases are narrower than something like an accutronics. There is no brand name that I saw. Their length is pretty much the full width of a 19" case. & they are hung on their sides with springs, one behind the other.
regards Rob
RuudNL
There is a solution for every problem!
http://www.vansteenisaudio.nl
abbey road d enfer
  It's the standard open-frame type available from Belton-Accutronics.
Rob Flinn
The dimensions would make it something like their type 9 tanks. Look here http://www.accutronicsreverb.com/ at type 9 tanks & the ones the KT uses are like the silver ones at the front of the pic.    I'll see if I can get a part number for the impedances.
« Last Edit: October 13, 2020, 08:32:26 PM by Rob Flinn »
regards Rob
Rob Flinn
Tanks used are accutronics 9DA2E1D
regards Rob
Last post September 02, 2006, 09:29:25 PM
by guavatone
Last post May 11, 2007, 02:12:58 PM
by chriss
Last post April 09, 2008, 05:53:31 AM
by flintan
Last post January 16, 2020, 10:01:48 AM
by squarewave
