Ampeg B15NC
Walrus
London, UK
The schematic inside the lid of our B15 NC doesn't match the actual amp circuit in that the amp doesn't have a screen grid decoupling capacitor as shown on the diagram. But a quick search shows that their are schematics out there that don't have the capacitor.
What would be the benefit or not of adding one?
It is just an additional filter-cap. It does not seem to me of any real significance, because the screen-voltage is already sufficiently smoothed out. It may add to stability though or another slight effect, as we know the screen-voltages do affect the function of the tubes, but I do not have enough knowledge of that.
Not bypassing the screens makes the tube work a liitle "triodishly". It means the internal resistance will be a little smaller and there will be a little more Miller effect. But its actually very minute. It is certainly measurable but not audible.
from a DC point of view it makes no difference.
when you crank the amp, there will be AC on the screen side of the resistors,
since this AC voltage from the push-pull tubes will be 180 degrees apart, they should cancel if the tubes are somewhat matched.
looks like they were getting cheap by using 1 screen resistor and getting cheaper by ditching the 20 uf cap.
now if you use two 1 K resistors for each screen and no cap, there will be a negative feedback effect, i think.  ???
