Api 312 input transformer question
« on: October 01, 2020, 10:01:10 PM »
Hi all
Just in case the old thread is TOO old, I found some scans and a pdf of an API 312 and, forgive me if this is a stupid question but, it has 6 holes for the input transformer but most available options have 8 pins.
Please can someone let me know what I am missing...
Thank you!
Khron
Re: Api 312 input transformer question
« Reply #1 on: October 02, 2020, 01:06:38 AM »
I'd be willing to bet the 8 pins on the transformers are four separate windings. The 6 connections would likely be 4 for the ends of the primary and secondary, and the remaining 2 for the center taps of the primary and secondary.
Comparing the schematics to the circuit boards would easily confirm that.
Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - Shenanigans
john12ax7
« Reply #2 on: October 02, 2020, 03:08:46 AM »
8 pins is a common package type,  but that doesn't mean all 8 are actually used.  The main thing is to have each connection go to the proper place.
Walrus
« Reply #3 on: October 02, 2020, 05:21:10 AM »
The original API 2622only has 6 pins.
Kevin.
Whoops
« Reply #4 on: October 05, 2020, 09:45:06 PM »
The 2 Pins diference are probably the Case/Shield and the Electrostatic Shield.
The Capi2622 , Ed Anderson 2622 , Avdo TR2622 and Cinemag CMMI-8APC all have 2 separate pins for Case/Shield and the Electrostatic Shield.
On the Schematic Walrus posted of the 2622 the Electrostatic Shield is connected to case and then both connected Pin4.
Maybe internally connected?
Last post June 18, 2004, 10:04:58 PM
by CJ
Last post July 16, 2004, 10:28:26 AM
by dmlandrum
Last post April 01, 2011, 08:44:42 PM
by Rybow
Last post March 04, 2012, 06:04:52 AM
by abbey road d enfer
