Vac11
FEELER: Moby´s T14/1 and C12A transformers reincarnations
« on: October 05, 2020, 07:25:49 AM »
Ive asked Moby´s if he can make a exact copy of famous T14/1 transformer and also copy of AKG C12A transformer. His answer was YES if there will be minimun run of 50pcs (T14/1) and 20pcs (C12AT). Same as in case BV08, BV11, BV12 we have an idea to make some transformers available for as low cost as possible to the DIY community.
So we wanted to see how much interest is out there. There is possibility buy these transformers at pretty much cost price with the proviso that payment is up front and turnaround is about 90 days from when all the preorders are taken. Of course, it's possible unless  the situation of  global pandemics changes.
We need 50 orders of T14/1 transformer and 20 orders of C12A transformer to cover production costs and minimum orders.
Info about T14/1 transformer:
-   fits C12, ELAM251 tube microphones circuits
-   ratio is  11,45:1
-   exact same dimmensions of bobbins and laminations as original
-   same winding scheme as original
-   same wire thickness and same color code
Price: 60,- €    CLOSED
Info about C12A (U11) transformer:
-   fits C12A cathode follower circuits
-   ratio is 1.84:1
-   not exact same dimmensions of bobbins and laminations as original (few milimeters difference), see Moby´s post number #10
-   same wire thickness, different color code
Price: 65,- €  OPEN
If you are interested in, pleas write here which type transformer you need and how much pcs…. I will prepare list of members who are in.
You can contact me here, on my email mildavaca (at) seznam (dot) cz or via PM on my facebook site facebook.com/vamisound
Best
Milan
Update, Oct. 19th: prices and minimum order has changed, see Moby's reply #32
T14/1         52    CLOSED
C12AT       26
List:
Vac11                                   1x T14/1, 6x C12AT
TillM                                      1x T14/1
Tony Hunt                          2x T14/1
Recording Engineer     1x T14/1, 2x C12AT
kvintus                                 4x T14/1
Aleguitarpro                     2x T14/1
Hitchhiker                         1x T14/1
Delta Sigma                         2x T14/1, 1x C12AT
Shabtek                                2x T14/1
Winetree                             2x T14/1
jrasia                                      3x T14/1
Avgatzeblouz                   3x T14/1
koki                                        1x T14/1
uptownsquash                4x T14/1
TLRT                                      2x T14/1
lampas                                  4x T14/1
audiophreak                     2x T14/1, 2x C12AT
Fenix511                             2x T14/1
100WChris                        1x T14/1
59flame                                2x T14/1
Meyer                                   4x T14/1
madreza                              4x T14/1
duatro                                   2x T14/1
kg350zw7                          1x C12AT
gabriel.808                        4x C12AT
ElSmurf                                1x C12AT
mainsman                          2x C12AT
stybljan                                  2x C12AT
Romain Bernat                   2x C12AT
BUKVALT56                        1x C12AT
justinheronmusic             1x C12AT
boops                                 1x C12AT
« Last Edit: April 10, 2021, 04:31:02 AM by Vac11 »
TillM
I’ll take one !
Vac11
Some pics attached...
tony hunt
I will take 2 x T14/1 to add to my collection of Moby iron.
The Moby BV12 I had was great!
TillM
To be clear I would take the t14/1 for a C12.
Recording Engineer
I’ll take a pair of C12A transformers.
Moby
Hey guys. Just to chime in. I made a tool for T14/1 bobbins but stopped there because I was busy with other work :( maybe it's time to continue. Btw, I have to double check the U11 (C12a transformer) winding scheme.
For microphone transformers,  BV.8,  Bv.11,  Bv.12, etc.. contact me at mobyelectronics at gmail dot com
Vac11
Re: FEELER: Moby´s T14/1 and C12A
« Reply #8 on: October 06, 2020, 05:05:36 AM »
Thanks Till, I did update list.
kvintus
4x T14/1, please
/Kvintus
...not perfect, but close enough for rock 'n' roll...
Moby
Hey guys, thanks for your responses. I carefully checked the details regarding C12a transformer building and  figured out that it does not share the same core size-laminations-bobbins with T14/1. It's slightly bigger transformer and this combo T14/1-C12A does not work.
Generally it's not "commercial" model of the transformer, so making custom tools for it does not give promises ;)
But, I would really like to help people who want to make C12A and maybe I can find standard laminations what can be used here. My idea is to keep original winding scheme, same DCR and inductance, lamination alloy, dual bobbin arrangement but +/- few millimeters will be the difference from the vintage original transformer. It will not affect the sound, just the overall dimension. I still don't know the total cost of it but I can try to make it the same as mentioned in the first post.
Are you still in? Should I keep negotiating with potential lamination distributor?
Regarding T14/1, I really want to start producing it, especially because I'm not happy with the sound of available clones on the market, including "the original one" what is produced in past 20 years.
So, if we reach the 50 pieces I will give my best to make it possible.
Try to spread this around, because I'm not sure how many people is checking under the "Magnetics".
Cheers :)
Recording Engineer
I’m still in for a pair of the C12A transformers whichever route you go. Also, please add me a single T14/1. Thanks.
Vac11
Re: FEELER: Moby´s T14/1 and C12A transformers reincarnations
« Reply #12 on: October 08, 2020, 12:39:01 AM »
Im still in... C12A circuit is long on my list!!!! Thank you.
Aleguitarpro
« Reply #13 on: October 09, 2020, 01:42:12 AM »
I'm in for a couple of T14/1.
Vac11
« Reply #14 on: October 09, 2020, 09:24:55 AM »
List updated!
hitchhiker
« Reply #15 on: October 09, 2020, 10:48:02 AM »
one T14/1 for me please!
lukas
« Reply #16 on: October 09, 2020, 12:36:26 PM »
T14/1 2pcs please.
shabtek
« Reply #17 on: October 10, 2020, 08:20:23 AM »
Two T14/1
"really fine players do not use stomp boxes or master volume, they match the amp to the room and turn it up to 11.  Stevie Ray, BB King, Albert King, Duane Allman, Dicky Betts, Louis Armstrong"
   -CJ
Winetree
« Reply #18 on: October 10, 2020, 01:01:33 PM »
I'm in for 2 - T14/1
jrasia
« Reply #19 on: October 11, 2020, 10:37:17 AM »
i'd be down for 3 x t14s
Last post August 11, 2016, 09:33:21 PM
by charlie2012
Last post January 06, 2021, 10:18:15 AM
by Vac11
Last post November 13, 2019, 10:48:35 PM
by pucho812
Last post February 19, 2021, 12:46:58 PM
by justinheronmusic
