andre tchmil
NTP 920 unknown version ?
« on: October 07, 2020, 06:00:06 PM »
I have a few of these NTP 920 meters here with a plastic back and a different connection layout than usual.
If I remember correct the original ones when powering up go to full scale and then slowly move back to the 0 position.
The ones I have in front of me are powered on pin 5+ and 6-. (think so !)
I slowly raised power from 5 to 24V, needle goes to full scale but doesn't drop to zero.
What am I doing wrong ?
andre tchmil
Re: NTP 920 unknown version ?
« Reply #1 on: October 07, 2020, 06:00:37 PM »
2
Conviction
« Reply #2 on: October 10, 2020, 06:09:55 AM »
The plastic backside (or is it mould?) is ANT:s work. Can you remove it?
I would try. Finding out what's going where is easy once you remove it (schematic in this thread: https://groupdiy.com/index.php?topic=59198.0). Less risky too.
I've never seen a datasheet for these M920's, so it's a guessing game, really. How did you come this far? Trial and error?
Also: if it doesn't fall back to zero, where does it fall back to? Could be as simple as adjusting P3.
andre tchmil
« Reply #3 on: October 18, 2020, 11:02:26 AM »
Hey thanks for the reply.
I will check and get back here.
Last post November 04, 2004, 05:19:17 PM
by Flatpicker
Last post March 05, 2007, 03:45:15 PM
by Twist Turner
Last post April 17, 2007, 10:08:03 PM
by Twist Turner
Last post May 15, 2010, 08:51:56 AM
by Soeren_DK
