Soundtrack sequel psu breakdown
duende
Active member
France
After a PSU capacitor recap on the Seqel 2 psu board the + 17v and the 5V don't work. All the components are ok visually.
The transformer secondary  are 24v, and after the diode bridge i mesure 33v and 0V. I don't understand how work the IC L4977A.
I mesure 33v at D1 negative and 0V after the +.
Have you have some info on this circuit ?
Thanks.
What exactly do you mean by this? ???
For what it's worth, the datasheet can be found here:
https://www.mouser.fi/datasheet/2/389/cd00000084-1795415.pdf
Yes the polarity is correct... And the -17V is ok .
I mesure 33V at D1/R2 and OV after D1/C2.
I have changed the diode bridge the last week but the problem is the same.
Sometimes when and i turn up the power the 5V led are illuminated during 1 second, maybe a capacitor charge ?
shotgunning parts is not a good approach.  having the -17 volts as o.k.  and the other not o.k. could still be related to caps.  You also may have a shorted transistors, a shorted resistor or any number of components that have failed.  You may even have a failed  IC L4977A. hard to say. The Schematic is hard to read.  the  IC L4977A looks to be a regulator. The pin out was provided. Should be easy to check if that is not working.  However if you  are not sure about it, I would take it to a repair shop. We doin't want you to hurt yourself to cause further damage.
Thanks everyone, i did find a bad solder and no connexion between the two layers...
The PSU work fine.
Thanks.
