sws2h
AKG BX10: No signal (wet or dry)
« on: October 11, 2020, 09:12:21 PM »
Hi, I recently purchased a BX10 that I was told was working, but I'm not getting signal, wet or dry, from either channel. I get around -65 to -70dB of hum which is probably pretty common for a spring reverb.
So far I've checked:
Power supply: voltage across the secondary winding and voltage across power supply output. Both good
Resistance between the pins of the reverb unit connector: Good
Continuity test input and outputs
I haven't tested the electronics according the what's in the manual because I don't have the test circuitry to do so. Here's a link to the manual and schematics: https://mpe.berklee.edu/documents/studio/manuals/effects/AKG%20BX10/AKG%20BX10%20Reverb%20Unit.pdf
I'm assuming I should see some AC on the circuit with power, correct?
« Last Edit: October 11, 2020, 09:47:26 PM by sws2h »
Last post June 15, 2005, 04:00:30 AM
by gyraf
Last post December 12, 2006, 03:42:54 PM
by mikep
Last post November 25, 2009, 07:33:45 PM
by Sleeper
Last post February 17, 2016, 11:02:44 AM
by livingnote
