wanted: API 200 series specs, technical measurements and edge connectors
I found some specs, they can get me where I can plan out where I need to go. Chassis is 7.25" deep.  so we can estimate a PCB depth. chassis is 3.5" tall which is 2 RU. Again we can make some speculations of card size, edge connector Size and so forth based on that.  It will be good enough for now. But if anyone has more detailed info let me know.
https://www.apiaudio.com/product_specs.php?id=119
wlinart said:
on the product pages of the modules are also dimensions, maybe those help too?
https://www.apiaudio.com/product_specs.php?id=113
it does.  it would be nice if they mentioned part numbers for the edge connector. But that helps a lot too. thanks
Plus it's interesting how different modules have different depth on the PCB measurements.  mistake or?
