I know many of you have played with the T4 photo coupler from the LA2A or LA3A, some have even built their own.
Now, has anybody measured the capacitance of the electroluminiscent foil in there? I've built a similar thing from a night light, and the capacitance seems very high (around 6nF). This means considerable loading, in both the tube and the transistor /transformer version. I know the control path has some frequency correction to even out the HF loss from this capacitance, but this is only a small signal correction. In the LA2A at least, the driving impedance being around 10kOhm, these 6nF would seriously limit the maximum voltage swing for high frequencies, even if the CV path has some compensation. (Slew rate limiting).
If the original has less capacitance, I can change the circuit to bhave the same with my higher capacitance (by making the driving stage "stronger"), but I have to know _how_much_ smaller the original capacitance is in comparison.
Anybody knows this?
(BTW, I had started a thread about a LA3A type step up transformer. By now, I think about going high voltage directly, instead. That would be using a 400V MOSFET for the CV path, complete with a little high voltage PSU (basically a LA2A CV path without tube), and the rest done at low voltage like the LA3A.)
JH.
Anybody knows this?
JH.
