Trench Recordings
drip 670 meter wiring?
« on: October 16, 2020, 08:40:46 PM »
My faceplate says IN GR OUT but looks like I wired it up the original way BAL GR BAL. Advantages of keeping it this way? How would I wire it so it was IN GR OUT?
Dave
Trench Recordings
Re: drip 670 meter wiring?
« Reply #1 on: October 17, 2020, 11:10:07 AM »
I do have two buffer VU kits from JLM I can use. I have to think about if it’s worth the effort to install these. I guess I would need 4 buffer kits
Rob Flinn
« Reply #2 on: October 17, 2020, 01:12:51 PM »
The 2 bal positions are there to match balance the audio stage to prevent the sidechain making thumps on the audio.    This is a very useful feature since the balance does need to be checked fairly regualarly & there is no other easy way to do it.
If you decide to disable this feature then you would need to switch the buffer pcb in when it was on "in" or "Out" & remove it from  the circuit when in gain reduction mode since I'm pretty sure the meter buffers won't like the roughly 300v the meter has on it in GR mode.
I never found I needed an i/o VU meter, because it's easy enough to know what your signal level is here on the preceeding & following pieces of gear.
regards Rob
Trench Recordings
« Reply #3 on: October 18, 2020, 09:49:06 AM »
Thank Rob, I found when I balanced with the multimeter on the two resistors as per the drip manual, it was thumping. Using the bal bal meter and balance it perfectly it also thumps. It seems better +1 -1 on the VU tuning it by ear under heavy compression.
Do you find the same on your unit?
Rob Flinn
« Reply #4 on: October 18, 2020, 10:52:02 AM »
The balance point can easily be different under heavy comprssion to th quiessent state unless you got extremely lucky with your 8x 6386.
regards Rob
Last post September 22, 2012, 05:41:51 AM
by DonnieDarko
Last post October 02, 2012, 05:53:05 AM
by Majestic12
Last post September 21, 2012, 05:41:08 PM
by Catscan
Last post December 30, 2019, 01:03:21 PM
by Pusch3l
