Hello gentlemen,
I recently purchased two 1176 kits, which use a board of an unknown origin (to me at least).
Both compressors work fine and are calibrated. The seller said they might be an early mnats version, but there is no documentation with the kits, so it's impossible to tell. Mike Havok from this group said the boards look like Gyraf, but they are not.
The compressors don't have input transformers.
I am having a problem with the input level - both units start compressing at a way too low setting of the input pot.
I am reading the Groupdiy forum since a few days, but can't seem to find a solution.
I stumbled onto talks about the R26 mod and the R1-3k7 mod, but cannot find proper information on which one does what and how should I perform them.
Of course, as an alternative I would be fine with a mod for rising the compression Threshold.
Would someone kindly point me to a place or link/s, where I can get the proper information, please?
My input pots are 10K, the output pots are 100K. The boards have Distortion trimmers, so they might be a D or F Revision.
The gain reduction and signal level FETs on both units are 245A.
I changed the gain reduction FET on one of the units to 2N5457 - no change.
Thanx for your time:
Nikolo Kotzev
[email protected]
