craigmorris74
Re: Spectra Sonics 110 pre with Opamp Labs 109 EQ
« Reply #20 on: November 05, 2020, 01:48:35 PM »
grid suggested a transformer on the output of the 325eq section, or resistor isolation.
the concept of  fader after the Spectra preamp is apparently isn't such a good idea as the eq needs a low impedance source.
My bad, my reading comprehension sucks apparently.
Got it.
Okay, Craig, what's your plan here? I'm interested in what you do with this. I was talking to Cyrus M (Mount Cyanide) a while back about collaborating on a project to make the OAL 109 EQ in 500 series format and maybe also as small boards that connect directly to dual switches. But I haven't found time to get a layout done and source modern replacements for the inductors.
I was interested in making a preamp/EQ channel strip.  I already have the OAL inductors.
rackmonkey
« Reply #21 on: November 05, 2020, 02:46:53 PM »
Right. I just meant what specifically you decide on the options you asked about and what you think of the results. Keep us posted if you would. Watching with interest.
Whether you think you can or you think you can't, you're probably right.
craigmorris74
« Reply #22 on: November 05, 2020, 03:18:54 PM »
Gotcha.  Will do.  It may take a couple of months, but I'll make sure to report back.
hodad
« Reply #23 on: November 06, 2020, 10:22:23 AM »
I don't know if it would work with the passive EQ circuit you've got, but the old Spectra Sonics consoles would insert the passive EQ in the feedback loop of the amp card, substituting the EQ for the 10K7 resistor (Attached pic shows a 101 amp card, but I think they did the same with 110s.)
craigmorris74
« Reply #24 on: November 06, 2020, 12:00:06 PM »
Thanks for the input and the picture.  The opamp labs circuit is actually a swinging input EQ.
craigmorris74
« Reply #25 on: November 06, 2020, 12:24:58 PM »
Could I put the OAL EQ circuit (without the 325EQ) in the SS 101 feedback loop?
rackmonkey
« Reply #26 on: November 06, 2020, 04:02:40 PM »
If it were me, I'd use the 1204 channel schematic as a guide. A lot more straightforward and it will definitely work. Putting it in the feedback loop is going to be tricky.
craigmorris74
« Reply #27 on: November 06, 2020, 04:16:26 PM »
Looking at the 1204 channel schematic and considering what I want to do, it looks like I could use the SS pre card in place of the 360BM, or take the output of the SS pre and run it into a 10K:10K transformer, then to the EQ.  Am I correct?
rackmonkey
« Reply #28 on: November 06, 2020, 07:57:44 PM »
I would use it just like the 360BM and tweak as needed from there.
craigmorris74
« Reply #29 on: December 17, 2020, 03:57:50 PM »
I've got the Spectra Sonics pres working and in the case, and I'm thinking about the 109EQ.  I thought I had a couple of 325EQ modules left, but I don't.  Could I substitute another opamp for them?
Craig
rackmonkey
« Reply #30 on: December 20, 2020, 01:39:56 AM »
...Could I substitute another opamp for them?
Craig
The important thing will be to present a 10k input impedance to the eq circuit at the inverting input of the opamp so the eq will function properly. Look back at the circuit diagram of the 325eq that I drew for the teardown post. You could try a 5534 with the same network at the inputs as the 325eq (a 10k resistor connecting non-inverting and inverting inputs with a 15uF cap to ground, and a 10k series resistor at the non-inverting inverting input). Certainly easy enough to try.
craigmorris74
« Reply #31 on: December 21, 2020, 01:30:28 PM »
Thanks for the tip.  Could I use this idea and substitue a couple of Yamaha 80200 lamps I have lying around?
rackmonkey
« Reply #32 on: December 24, 2020, 11:58:16 AM »
Not familiar enough with those Yamaha amps. Post a schematic if you have one.
craigmorris74
« Reply #33 on: December 25, 2020, 11:53:45 AM »
Here the schematic.
rackmonkey
« Reply #34 on: December 25, 2020, 03:56:39 PM »
Same approach as I outlined above should work. Give it a try and see.
craigmorris74
« Reply #35 on: December 25, 2020, 06:43:39 PM »
Excellent.  I'll give it a try and see what happens.
Whoops
« Reply #36 on: January 06, 2021, 10:46:27 PM »
Hi Craig, could you please let me know how did you rack the SS 110 cards?
Like the wiring layout and how you took care of gain/attenuation?
I also have some cards I would like to rack
Thank you so much mate
mjrippe
« Reply #37 on: January 07, 2021, 01:56:00 PM »
Whoops, Have you read the document by Richard Guy?  He covers all aspects of wiring SS cards as preamps.  The one I have is for the 101, but should be nearly identical.
craigmorris74
« Reply #38 on: January 08, 2021, 08:38:14 PM »
I'll make a detailed wiring diagram in the next few days.
craigmorris74
« Reply #39 on: January 09, 2021, 06:59:17 PM »
Here's a wiring diagram I whipped up.  If anyone spots any mistakes, I'll fix it.  I wired this according to what JLM and Matta posted on the "Racking Spectra Sonics 101"  thread.
Last post February 02, 2012, 10:53:01 PM
by Whoops
Last post February 15, 2008, 12:03:37 PM
by electrochronic
Last post May 22, 2017, 03:56:54 PM
by bxt403
Last post October 18, 2009, 11:23:37 AM
by Tim the enchanter
