I've got a Cinemag 24110 (
https://cinemag.biz/mic_output/PDF/CM-24110.pdf) that's behaving strangely.
I measure ~350R between each of the primary leads and the center tap, but I'm not getting any voltage on the center tap when I apply phantom power to the secondary. If I make a virtual center tap (with 2k2 resistors) and pull the center tap, I get phantom power at the virtual center tap as expected, and mic sounds right, so I know that the transformer is working otherwise, but I still get 0v on the transformer's center tap.
I've got another mic with a very similar transformer (same wiring, different ratio:
https://cinemag.biz/mic_output/PDF/CM-24110.pdf) sitting here that is working as expected. I've noticed that I get thousands of ohms of resistance between the leads and the center tap, though, which is (a) not what I would expect but (b) definitely different from the other xfo.
I should mention that I did do one bad thing: I had the transformer flipped around backwards at first, meaning I had the primary connected to the XLR pins, which means at least hypothetically I put DC across the transformer, but I don't know how I could damage only the center tapping and not the entire transformer.
Does anything about what I've described sound like I borked the transformer such that replacing it would help? Even though the mic is working, philosophically I'd prefer to use the actual center tap.
