saint gillis
Mastic Glue for electronic components
« on: November 07, 2020, 06:23:15 AM »
  Hi, this have already been discussed in this forum, and the main conclusions were always to use two kinds of glue : Shoe Goo, and E6000 (Someone even mentioned that Oliver Arshut used E6000 for very high impedance zones in condenser mics with great success)
  But when I'm looking at the brown mastic used on several power amplifiers to glue the big psu capacitors, or when I'm looking on the white mastic used on Meanwell switching supplies to glue several components, I want to know what it is !
  I've tried MS hybrid polymer, it looks very similar to the Meanwell mastic, but it's flamable when it's dry, although we can buy fire retardant versions.
  Does anyone have good knowledge about that ?
abbey road d enfer
Re: Mastic Glue for electronic components
« Reply #1 on: November 07, 2020, 10:57:57 AM »
I would think it's hot glue.
saint gillis
« Reply #2 on: November 07, 2020, 12:37:59 PM »
No... It's harder, it doesn't melt, and it's not flammable if you put fire on it...
abbey road d enfer
« Reply #3 on: November 07, 2020, 02:15:27 PM »
Could be epoxy...
peterc
« Reply #4 on: November 07, 2020, 02:50:33 PM »
Might be worth asking on the Soundproofing/Acoustics forums. Mastic is quite commonly used as an air sealant in panels and composite boards.
« Last Edit: November 08, 2020, 04:56:50 AM by peterc »
If opportunity doesn't knock, build a door.
saint gillis
« Reply #5 on: November 08, 2020, 11:57:22 AM »
It's not epoxy, it's softer...
This is the white mastic we find in switching psu's :
This is the brown glue we find on many power amps and many pieces of gear : https://i.redd.it/e1gaw8utbjz11.jpg
rackmonkey
« Reply #6 on: November 11, 2020, 02:36:11 AM »
Silastic by Dow. Silicone.
There are also products called “assembly pastes” for electronics like Loctite Ablestik that are similar. They usually have PTFE (teflon) in them, which explains the color and non-conductivity/non-reactivity. Expensive.
But why not save the trouble and expense and just use white silicon caulk, like you’d seal a sink or bathtub with? It’s pure silicon and as such is non-conductive. GE makes a product called Silicone II that doesn’t offgas corrosive stuff and I’ve never had a problem using it for upside down caps in guitar amps.
« Last Edit: November 11, 2020, 02:41:13 AM by rackmonkey »
Whether you think you can or you think you can't, you're probably right.
Last post December 12, 2007, 05:58:43 PM
by princetown
Last post August 10, 2009, 06:47:45 PM
by roy
Last post September 27, 2010, 12:52:34 PM
by zayance
Last post September 06, 2012, 11:28:25 AM
by Gold
