WSW preamps connectors
beatnik
Italy
Hi
I have a pair of WSW preamp that I need to rack up.
Each preamp uses a pair of 10 pole Tuchel connectors.  They look similar to the DIN41622 connectors used in Telefunken V72 and others but
I cannot find these connectors anywhere, I am feeling it was perhaps a custom part for Siemens / WSW
I have attached a photo of the connectors on the preamp modules
If you have any lead about finding the matching connectors that would be awesome
IIRC these were made by AKG, and are very hard to find now. Try disassembling a standard large 3-pin Tuchel female cable connector, taking out just the pins alone to see if they fit the blades of the connector on the preamp? My guess would be yes...
Hi
Hello...I am in the same situation..May I ask what did you do with these hard to find connectors?
Thank you
