Hi!
Just want to share some picture of my latest summing mixer. It is a modified version of a summing mixer i did some years ago, with neaw features in the front panel. I'm looking for opinions about the features. Because some potential users may like to have this or this....
Basically I want to make sure the features are useful enough for studio use.
List of features:
1. Signal present / peak indicator at the output of the summing amplifiers. -20/-2 dbu.
2. Insert Blend fader and switch. (pre-fader).
3. Added a Mono switch to convert channels 1 to 4 in mono without loosing inputs. When engaged the MONO switch, channels 5-8 remain stereo. Otherwise with MONO disengaged all channels are stereo.
4. Output type switch as in the initial version. Selects output type: Electronic balanced Line driver or Lundahl transformer.
5. Big Mix output level knob as in the initial version.
6. And finally added Mix Output level Peak leds / Vumeters.
7. 32ch in db25 balanced format. But also a 16ch input version, upgradable to 32ch.
8. Balanced Send/return insert point pre-fader TRS jacks
9. Stereo TRS jacks for expansion input.
10. Mix outputs and multed Monitor outputs (to an external monitor controller) in XLR format.
11. Sound quality: I tested the mixer against an SSL Duality Delta, and we could compare the sound with a mix session they were doing: They sounded equal!! until we engaged the Lundahl transformer output (LL2811) in the Mikrosum... then we all could hear the difference: ¡Wow!! A good and punchy low end...
I would like to have some opinions, or questions, I will answer here!!
Jay x
