Hi All,
I'm somewhat new to hooking up toroidal transformers, the only capacity that I've worked with them in the past was rebuilding/recapping my console power supply and had no issues hooking it back up after I was complete.
A few months ago, I purchased the DR-MQ5 Sontec clone kit from DIY-Racked and quickly gathered the parts and put it together. Once complete, I followed the instructions in the wiring document (attached screenshot) for the toroidal transformer, fired it up, and.....nothing. I'm not getting any measurable AC or DC current and have tried a few different fuses, IEC inlets, etc. with no success.
I emailed DIY-Racked and they believe that the transformer is faulty/needs to be replaced but after looking up how to test it with a multi-meter, I confirmed that it's in good shape.
I have the feeling that something isn't wired correctly but can't seem to figure out what it might be. I've attached a screenshot of the wiring diagram and a few photos of the IEC/Toroid/Switch that it's attached to. Let me know if the pictures in the PDF aren't large enough or if additional pictures are needed.
Any help is greatly appreciated, I've already purchased Elma switches to put in after I've measured the test points and really don't want to start assembling them until I can check the test points.
