Sourcing Chassis
C_F_H_13
Member
Hi All,
What are most people doing for sourcing chassis for DIY projects, specifically standard rack format 1U/2U/3U cases? I am in the process of building something that will live in a 3U chassis, so I'm looking for recommendations.
I'm in Canada, and Hammond (which is local) has options, but they are in the range of 300-400$ for an empty chassis I would still need to modify and put together myself.
I really don't need some super robust high quality one, I am looking for cheaper options as I'd rather not spend more on the chassis than everything that's inside it :)
Any suggestions would be greatly appreciated.
abbey road d enfer said:
Unfortunately, that's pretty much the reality. Metalwork is the most expensive part of almost any electronic product.
Yeah I had a feeling that would be the answer, still looking for options though of any price point.
Also mods I put this question in the wrong sub group if you want to move it to Machine Shop!
Here are a couple options
Par Metal
http://www.par-metal.com/
Collective Cases
https://groupdiy.com/index.php?topic=41963.0
The white market and black market in general can be a good place to find things.
For standard 19" rack i use modushop. Good range of cases for good price.
I don't know how much it could cost to ship to canada though (They're in Italy).
Par Metal
Collective Cases
+1 on Par-Metal
JohnRoberts said:
I built a lot of early stuff into the gutted out chassis of older products.
This was actually suggested by a friend as well, and actually would be fairly easy to do, as I have a closet full of older useless rack gear.
One of the first (small) audio amps I designed was built into an old consumer amp chassis. I was even able to re-use the power supply from the original amp. I built this audio amp for my younger sister (RIP) to use as a record player, and she used it for years.
+1. You can get a really nice, ancient rack mount device from ebay that has much nicer features than a modern generic chassis, strip it and use it. And you get some usable vintage parts out of it, if you’re willing to go to the trouble. I have a couple of old Dynair boxes with 4 slide-out trays that I built 4 preamp channels into for each unit. I think I got both for $90 plus shipping.
You can find surplus Middle Atlantic chassis for pretty cheap sometimes on ebay. Not as nice as a Hammond or Par Metal, but perfectly serviceable.
Otherwise, the options given above cover most of the usual suspects.
Par Metal
Collective Cases
Add Bud Industries in Cleveland Ohio to the list (www.budind.com)...
