According to things I am reading today
All amplifiers “ the good ones”, all sound the same.
That their purpose is to be the straight wire with gain.
While I do like and agree with the last part about wire with gain, I am wondering what constitutes “the good ones” and how one can make such a claim?
It depends very much what category of amp. For years I used to think that nothing could beat a Crown 5002VZ. It used to be in the heavyweight category, until the norm became 10-20kW in a 2U box.
There are audible differences in this category. There's bound to be, when the box can put out 10+kW whereas it takes its power from a 117V 25A outlet. Every designer has their own compromise as to solving this seemingly impossible equation.
But I reckon you're not talking about this category.
Typical amps used in studios use power supplies that allow continuous operation at max power. One of the big points of difference is how they handle complex loads.
Years ago there was a comparison of power amps used in conjunction with real speakers.
One of these speakers was so hard to drive that only one amp could drive it without restraint, the Crown PSA2.
A Sony amp, that had an amazing rise time of 0.35us (yes, 1MHz BW!) could only deliver about one third of its max power on them. Some amps failed miserably at one-
tenth their max power!
Although the Sony was unfaultable on typical tests, done with a resistive dummy load, guess which one sounded best on these speakers!
Even the usual capacitive load test could not hint to this difference.
The big difference was that he Sony, as nearly all the others used the usual reentrant protection that samples the emitter currents and adds it with a dose of Vce. The Crown was the 1st commercial amp to use the analog modeller that simulates thermal dissipation and secondary breakdown.
Most class-D (switch-mode) amps are capable of driving very complex loads without undue distortion, but the intrinsic performance is not always excellent. The usual tests would allow assessing performance adequately.
Now, another category is audiophools, who think perfection lies in a Single Ended 211 in class A, with 0.5% THD at half-power.
