Coop
Blue Bluebird to Neumann CMV563/UM57 MOD
« on: December 19, 2020, 09:35:54 AM »
Hi All,
I recently cleaned up my mic collection and found the first ever large diaphragm condenser mic I bought. A Blue Bluebird. Did have some great time with this mic but I always found it sounded a little bit harsh.
Haven't used it in a while and I thought it would make a nice donor body for a CMV563/UM57 build.
So my idea is to implement a the UM57 circuit in the body with a nice M7 style capsule in the original head basket.
So I will basically have a Mic that looks like a CMV563, always liked the look of it, with the ability to switch between different polar patterns.
Right now I'm looking into sourcing all the components for the circuit and build a prototype point to point board and pair it with the stock Blue capsule and one of my N61 PSUs I have from my M582.
Will post some pics in the next couple of days. And I'm open to ideas and suggestions.
Best wishes,
Johannes
Re: Blue Bluebird to Neumann CMV563/UM57 MOD
« Reply #1 on: December 19, 2020, 11:20:24 AM »
What tube do you plan to use?  It looks like a 12AT7 might work to replace the EC92.  The AMI UM351 seems like the transformer to use, or do you have another one in mind?  I might try building one of these next year, since I have lots of NOS 12AT7 tubes to try.
Coop
« Reply #2 on: December 19, 2020, 11:38:58 AM »
Well I think I will use a NOS Telefunken EC92. Do have one laying around from one of my M582s that I can use as a test tube.
I was thinking about the AMI UM351. But I also heard that someone used the Cinema 2480. Need to do some more research on that. Would love to find the most parts located somewhere here in Europe.
Recording Engineer
« Reply #3 on: December 19, 2020, 02:42:00 PM »
Can also use a BV08-type... If it’ll fit. I’m thinking about that (since I’ve a number of them from various manufacturers), but with an Amperex 6084 tube since I have a couple of those laying around also.
mjrippe
« Reply #4 on: December 19, 2020, 02:50:46 PM »
No point in using a 12AT7 when you only need a single triode.  EC92/6AB4 are not expensive.
Pip
« Reply #5 on: December 19, 2020, 05:09:38 PM »
I want to know if you can even open it up, because if it is anything like the baby bottle its glued shut!
Pip
New York City
http://geosonixlab.com
Coop
« Reply #6 on: December 20, 2020, 03:56:28 AM »
@Recording Engineer
Good to know that. There is actually a lot of space in this little mic.
@Pip
Opening it up is super easy. Just unscrew the bottom ring and you can slide of the tube.
Coop
« Reply #7 on: December 22, 2020, 12:57:03 PM »
Bought some acrylic glas and started building the prototype boards. Now I'm waiting for the rest of the parts to arrive.
Last post May 25, 2013, 12:56:10 PM
by zebra50
Last post September 09, 2008, 11:17:29 PM
by natek
Last post June 06, 2013, 10:10:55 PM
by JimiDeez
Last post November 08, 2020, 10:35:31 AM
by Rohan white
