Hi!¡¡Happy holydays!!I'm trying to build SSL filters HPF and LPF. And i think i confused myself a bit. For instance, in the schematic RV6 i thought it was a regular potentiometer, but it seems a preset pot. RV6 5k linear i suppose. This is to set the LF filter corner. RV5 is also a preset pot, to be set to match R56 300R.And, for the triple gang reverse log 47k i know audiomaintenance has them. But i would like to find a smaller one even if it is 50K. ¿does it make much difference 47k vs 50k?, maybe just a bit more attenuation.¡¡Happy holydays and stay Safe!!Jay x
Hi!Well, after some research, i think yes, the only controls of both these filters is frequency,
Hi!Still studying the schematics... In these filters, the frequency is adjusted clockwise. ¿correct?, so for the LPF the lowest frequency is when the potentiometer is fully anticlockwise so the B and C sections wipers go towards ground. The A section rotation is not signaled, but if it is wired as the other sections..., clockwise rotation is wired towards the R64 10R output resistor...¿right?
well, you would want to bring your HPF from "nothing" and up to whatever the max rage is for. The LPF you would want the opposite. Start at the max and turn down to the minimum.
That is not the way it's usually done. Both the LPF and HPF increase frequency CW.
Started by atticmike Drawing Board
Started by pahstah « 1 2 ... 5 6 » Filters/Equalizers
Started by donzo93 Drawing Board
Started by Cheadle96 The Lab
