I don't understand about why people remove the HPF in a microphone like a U67.
I would think you would want a HPF in the range of 20Hz to 40Hz if you don't have a treated room.
I would think it is better to remove the low frequency rumble etc. before sending it to a preamp. Less junk to cause IM distortion.
I have added a 12dB HPF at about 30Hz in microphones and on the list of things to build is one with a 4th order HPF at about 20Hz.
Certainly, filtering out subsonics from the very start makes a lot of sense. However, the way it is so often done has serious drawbacks.
It is a very simple scheme that puts a resistor in parallels with the capsule for increasing the -3dB LF cut-off frequency, but it has the big disadvantage of increasing noise.
With a very low cut-off frequency, the "capsule noise" (or QTC noise) spectrum is dominant at infrasonics, so inaudible.
By raising the cut-off frequency, the spectrum is shifted in a way that it becomes audible and questionable.
The proper way consists in operating the capsule and first stage with a very low frequency cut-off and following it with a separate filter. that's the way it's done in the AKG414 or Neumann U89, for example.
Others do it by introducing selective feedback.
