Dual TO-92 heatsink
Norfolk - UK
I seem to remember in the dim and distant past you could get a small heat sink that took a pair of TO-92 transistors so you could thermally couple them. They had a couple of legs so you could solder them to the PCB as well. Can't seem to find them anywhere. Do they still make them?
Did you search under "Buggy Whips"?
I couldn't find them either. The one clever thing I saw was two TO-92's face to face in a hex nut, likely 1/4", secured with a little epoxy.  Find an aluminum nut, reduced mass after all, and you're cool.
I don't recall those. As Dan mentioned I have seen people put two to-92 face to face and screwed a nut on the pair.
You might be able to repurpose a press on heat sink for round metal cans, like to-5 (probably loose), or to-39 probably too small.
Back in the day I used transistor arrays to get good thermal tracking, but device parameters are limited.
I superglued the flat faces together, and then fashioned a ring out of copper sheet cut to a bit more than the height of the TO92 case to surround the two transistors. It stays on by the fit of the copper band. Works well.
this one ?
https://www.fischerelektronik.de/web_fischer/en_GB/heatsinks/C03/Small%20heatsinks/$catalogue/fischerData/PG/KF5_5/search.xhtml
ijzerpro said:
this one ?
That is meant for a T05 can but it occurs to me you might be able to place together the faces of the two 'D's of a pair of T072 transistors to make something more or less circular in which case a T05 heatsink might be just the thing.
ian
I now use aluminum acorn nuts for ZTX851 "E-Line" (TO-92) differential pairs.
They're glued with epoxy. I would not use super-glue: A customer tried that and the devices melted.
