Hello all,
I inherited a Chilton CM4 mixer from a friend. This mixer has somewhat been modified to work in a broadcast remote situation, and I want to restore it to original 'cause its present functionning is inappropriate for my needs and I also think it's acting weird and it needs to be straightened out.
Now I know you're gonna say there's a manual for the CM2/4 that's easily available, but I have that and it's NOT what I need. I need documentation for the CM4 specifically, because there are differences between the CM2 and the CM4 that are NOT covered in the available PDF. One is the connector that links the master modules: on the CM2 it's 15 pins, and on the CM4 it's 24 pins...
So if you have this kind of information, would you mind sharing?
