Hot swapping capsule on bayonet microphone
ubxf
los angeles
The Blue bottle mic is supposed to be able to handle swapping capsules while the mic is powered. Would it be the same for a RFT 7151? i always power off the mic but i guess it might not be good for the tubes.
Neither the capsule nor the tube should suffer when hot-swapping. The EF12 is good for several thousand turn-on/turn-off cycles; you shouldn't really worry about that.
