Hi!
I'm currently finishing the design of a 500 series preamp based on the VPR alliance dimensions specs.
From this pdf information, if I add an L bracket made of 1mm thick aluminum, between the pcb and the front panel, I have to diminish the size of the board by 1mm accordingly.. ¿is this correct?. If i don't do this the front panel would not make proper contact to the case rim. ¿right? My board length is right now 150,51mm.
Thank you for your advise!!
Jay x
Jay x
