A-24 backwards crossed my mind. RCA used it that way as an API type preamp input.
Ah, now that's a thought. 600:15k then, right? Is my math correct that that would result in a gain of nominally 28dB?
Speaking of the pots, I'm frustratingly close to a clue here from these photos (attached)
The input pots are actually visible in some of the photos I kept. Zooming in, you can piece together that the rear seems to say "721304 - 003"
This is definitely not an EIA code because it doesn't match A-B's EIA number. Apparently the model numbers stamped on the rear of the Type J pots changed a few times, and none of the datasheets I can find have helped me to decode this varietal. It's tempting to assume that the "304" means "300k" but that's far from conclusive, and besides I don't think that was a standard value for the Type J (35k was).
Additionally, you can
almost see how the mystery transformers are connected. I'll scrutinize this a bit more later and see what I can come up with.
