So it seems like part of the leaf switches are broken so I would like to design a relays system that will replace the original switches. I was thinking about using dual relays but there's one thing I don't know how to do.
It's easy to create the switching mode that appears on line 20 when point 51 connected to the purple pole and point 25 connected to the red pole.
Now things becomes tricky on lines 21-25 when points 51 and 52 should remain at the same switching position while point 1-5 and 11-15 should be changing according to the switching mode.
Maybe someone here having a good idea how to do this switching?
